View Virtual Neighbors
View virtual neighbors to view the area and virtual link configuration for the neighboring device.
Change the VRF instance as required to configure OSPF on a specific VRF instance. The VRF must have an RP trigger of OSPF. Not all parameters are configurable on non-default VRFs.
- Select OSPF.
- Select the Virtual Neighbors tab.
Virtual Neighbors Field Descriptions
Use the data in the following table to use the Virtual Neighbors tab.
Name |
Description |
Area |
Specifies the sub-network in which the virtual neighbor resides. |
RtrId |
Specifies the 32-bit integer (represented as an IP address) that uniquely identifies the neighbor router in the autonomous system. |
IP Address |
Specifies the IP address of the virtual neighboring router. |
Options |
Specifies the bit mask that corresponds to the neighbor options parameter. |
State |
Specifies the OSPF interface state. |
Events |
Specifies the number of state changes or error events that occurred between the OSPF router and the neighbor router. |
LsRetransQLen |
Specifies the number of elapsed seconds between advertising retransmissions of the same packet to a neighbor. |
HelloSuppressed |
Specifies whether hello packets from the neighbor are suppressed. |
RestartHelperStatus |
Specifies whether the router is acting as a graceful restart helper for the neighbor. |
RestartHelperAge |
Specifies the remaining time in the current OSPF graceful restart interval, if the router is acting as a restart helper for the neighbor. |
RestartHelperExitReason |
Specifies the outcome of the last attempt at acting as a graceful restart helper for the neighbor. |
